Shower help
12 Apr 2013
Nottingham
Hi guys
I've been directed to this site by a friend who swears by it, now I have a shower which I cannot identify and as it stands I have the following problems:
1) I cannot change from normal shower to hand held shower head as its practically seized
2) we struggle to adjust the temp on the other valve as it is soooo stiff.
I have taken it off the wall and will attach pics but my concern is my misses is pregnant and when I work away she struggles to adjust is and if she was to slip while trying to adjust it would be a nightmare
So all comments greatly received
Matt
upload your pics to showerdoctor .com and they mihjt be able to identify it and supply new valves if you wish.
If you can remove the valves from the wall, strip them down and clean. Often works, though I realise that is probably easier said than done!
Give it a whirl then! Lube it all up with silicone grease when you reassemble.
