Well I have an 8.5KW shower working fine on 6mm wire connected to a 30A separate rewireable fuse box, I'm sure this was fine before the part P regulations in 2005, I wanted an RCD for peace of mind. the double pole switch/wiring is fine and has been working since with no problems, but with budget restraints, I still haven't been able to replace the fuseboard with a new unit, so just fitting an RCD/RCBO box incl. labour & parts, how much would it cost? and I still don't know which one should be used and the difference?
Thank you.
Thank you.
