Shower mixer for low pressure
29 Aug 2011
London
I am looking for a shower mixer that's good with 0.1 bar pressure. The bathroom originally had a bath tap mixer that gave acceptable flow. I am looking for something simple, ideally a manual mixer that accepts 22mm feed. Basically, I am trying to replicate the bath tap mixer, without using a bath tap mixer. Anyone knows of such a thing?
'Fraid to say the only ones I have ever found that are really any good with gravity feeds are the bath deck mixers, that it sounds like the one you have. They have large waterways and wide shower hoses that maximises flow.
All the others (exposed/concealed/bar mixers) are quite restrictive with narrow waterways and only work properly under mains, no matter what they say their min pressure rating is.
What is the possibility of mounting a deck mixer on plasterboard and tile wall?
This regular mixer claims to have high flow. Just bull ox?
That's not a deck mixer, that's an exposed thermo shower, same issues as far as narrower waterways and a thermostatic cartridge are concerned being restrictive to flow.
Anything that isn't compression type/screw down valves with full flow pipework will be restrictive in a gravity fed setup. It's just the nature of things unfortunately. The only other option would be to install a bespoke wall mounted setup where there were the 2 hot and cold taps/valves with a diverter to port the flow to either a bath filler spout or up to a shower. Even then though you need to ensure the diverter and shower head isn't restrictive to flow @ low pressure either.
Very little choice when it comes to gravity supplies unless it pumped or the cold water cistern height is increased significantly above the shower head.
It claims to work but common sense would say the water has some work to do navigating the restrictions.
restrictions.
Ok, I can see it's a dead end - I had some inklings of it but wasn't sure. The simplest solution is to go back to the original set up of a bath and tap shower mixer combo. It worked originally, and should work again.
Am I in luck, or am I still wishful thinking? While thrashing around, I found these. Any reason why these won't work? These would resemble the deck mixers.
A typical breech mixer diagram suggests there is no complex restriction in the mixer.
They may do yes - certainly look like a free flowing design and as there's no thermostatic valve to go through then they would certainly flow more. Only compromise is no auto temp control. Don't forget widest possible shower hose and hi flow shower head too.
Doesn't the shower hose come in one size? The connector on the valve looks to be only one size.
As far as the end fittings are concerned then yes - usually all are 1/2" BSP - as far as the internal diameter (ID) of the actual hose is concerned then nope. Largest ID I've found are the MIRA hoses.
