We've had a shower powered by a Salamander CT50 twin pump for 3 years and it's worked perfectly.
Out of the blue the other evening, the pump motor started all by itself and would not stop without being switched off. There's nothing loose on the pump and no sign of any water leaks. I've also given it a few small knocks in case one of the pressure switches was jammed - but to no avail.
By switching the pump on and off manually I've had a perfectly normal shower today so it is working ok.
Will I have to replace the pump or is there anything else that might be causing the problem? Any other suggestions?
