I recently installed a new 3 bar shower pump on the ground floor of my 4 storey terraced house to feed a new shower room on the 4th floor. The pump is situated within 1 metre of the hot water cylinder on the ground floor and is fed hot water from the cylinder via a surrey flange. The shower pump's cold water feed comes from a roof tank situated above the new shower. Pipework between the pump and the shower / tank / cylinder are continuous lengths of polyethylene (PE-X) barrier pipe and connected with push-fit fittings except where it connects the surrey flange.
The pump works a treat and supplies nice water pressure to the shower in the new bathroom. The problem I have is that 99% of the time it refuses to turn off. When the shower is shut off the pump downstairs begins 'pulsing' as if it is turning itself on and off. At first it appears that the pump has shut off but then the pulsing begins. The only way I have found to turn it off is to gently ease the shower back on and turn it off again very slowly, but this is not guaranteed to work every time.
Does anyone have any ideas what could be causing this? Is it a rush of water back to the pump from the shower that is triggering the pump mechanism again? Would fitting one way check valves prevent this at all?
Any help is appreciated as I have run out of ideas.
Thanks,
Jez
Thanks,
Jez
