Which combi?
The more problematic scale is usually the stuff on the primary (boiler) side of the secondary (hot water) heat exchanger (dhwhe). The secondary side can be affected with limescale, which usually reduces the flow of water.
Some combi/thermostatic mixer combinations interact with each other too.
If you do a few searches you should find some case histories.
