Hello,
I'm having a new shower tray fitted and have had two plumbers round to look at the job so far. The trouble is that both plumbers are reccomending slightly different approaches and I dont know which is more appropriate.
Plumber 1 recomends that I get:
- A shower tray with upstands,
- Then build a wooden frame for the shower tray to sit on to minimise movement,
- Using cement board as a backing board behind the tiles.
Plumber 2 reccomends:
- Says that upstands are not worth it, as as long as the tray is properly installed there is no need for upstands.
- Says that there is no need for a wooden frame as onces again, as long as the tray is properly installed, the legs properly screwed down, and that plenty of good quality silicone is used there should be no need for a frame.
- No need for cement board, Marine ply sealed with pva would be best.
Option 1 sounds like the the belt and braces approach to me, but is this overkill and adding unnecessary cost ?
I thank you in advance for any advice you may have.
