I'm currently refurbing my en-suite and am at the stage where I need to fit the shower tray. They tray I'm using is an ABS acrylic capped stone resin 900 x 800 with riser kit from Victoria Plumb.
The riser kit comes with 8 adjustable legs that are attached directly to the base of the tray with adhesive foam pads. The underside of the tray has 5 machined circular flat spots for attaching the legs to (one in each corner and one in the middle). The kit is obviously made to fit several different size shower trays which is why there are more than 5 legs).
When I first trial fitted the tray with 5 legs I was not happy with the amount of flex / movement so I added the remaining 3 legs and moved the centre leg so I now have one in each corner and 4 in the middle. This has reduced the movement / flex but there is still a small amount of movement when I stand on the tray and shifting position, particularly when standing near the front corner of the tray.
The tray is positioned in the corner of the room so it buts up to 2 wall surfaces. When I fit it permamanently I will run a bead of silicone sealer / adhesive between the wall and shower tray to help stabilise it.
The floor is standard 18mm chip board covered with 6mm No More Ply sheets.
My question is ..... how much movement is expected/reasonable to expect at this stage? Is it normal for there to be a small amount of movement or should there be no movement at all? If I the latter, what is the best way to eliminate all movement with this type of tray? For example, should I remove the legs and attach some 18mm WBP ply to the base of the tray and then re-attach the legs to try to reduce any flex? Should I attach a sheet of ply to the floor on top of the cement board? Should I put some adhesive under the feet? Or should I just stop worrying and fit it as it is?
Any advice greatly appreciated.
