shower water only running out slowly
25 Feb 2008
Durham
my inlaws have just moved house and found that the shower,which is a Bristan design utility club bar shower with adjustable riser and amp,is only flowing water very slowly,also the "tap" doesnt seem to turn more than 1/2 a turn.Water flows well from all taps in the house,just the shower has the problem. Does it need a new "bar"?
Holes in the head first!
They often have filter washers at the inlet which become blocked with debris after a while.
sorry,should have mentioned that they put a new shower head on but still the same.
thank you both for taking the time to reply,i will give it a go.....is it just a case of cleaning the washers or do you recommend changing them?
