- Joined
- 5 Oct 2016
- Messages
- 16
- Reaction score
- 0
- Country
Hello all,
I appreciate that this has been asked and covered a few times, and I think I've worked out an answer but I'd appreciate some additional feedback
First issue was that the shower cuts out after about ten minutes of running. Curious. The MCB in the consumer unit was warm, but I wasn't sure if this was an issue.
So I looked at working out what the MCB was rated at, and what the shower was etc, this lead me to also check the cables.
So the shower is 9.5kw, that's easy - it's written on it.
The MCB is labelled "type B, 5a M1, 14-45A m2" - internetting makes me believe this is a 5A MCB which confuses me, it looks just like the one for the lighting ring, but could it really be 45A?
I can't get to the cable that goes to the shower completely, but I can some of it, and so you can see in pictures that I've attached below that I can see the cores - they're about 5mm in diameter, from what I can see of the grey cable housing it looks to be larger than 10mm across which makes me assume it's not a 6mm2 cable, and probably a 10mm2 cable and therefore sufficient for the shower.
https://imgur.com/a/OrfEq
So, the questions are:
1) is that really 10mm2 cable?
2) does the MCB seem the right size?
I noted after taking off the neon isolator switch (I believe the previous occupants have re-routed the supply from the old immersion tank when they switched to a combi boiler) I also noticed that one of the black cables had basically fallen out, so I've re-terminated that now (could that have just been the problem all along?)
Thanks in advance,
Thanks in advance,
