I have a shower which is roughly 8 metres away from a show pump in my airing cupboard. The existing piping (22mm) goes up into the loft at which point it converts to 15mm and then to an ensuite.
The flow is great, which I'm assuming is the result of the pipe 15mm constraints.
I do not want to take the shower out but can get to the pipes on the elbows behind the shower.
My question is, if I replaced the elbows with 15mm/22mm and 22mm across the loft floor would the performance be better or is there still going to be a constraint at the 15mm shower inlets?
I hope this makes sense.
Thanks.
Thanks.
