Sick of Mould behind radiator
The wall
So the radiator is a red herring then; it’s just a patch of cold wall.
What is the construction of the wall?
Cavity wall (not insulated)
I'm not so sure it's a red herring bevause the wall temp was measured with the rads off during various points of the days and thd entire wall showed a virtually identical/consisted temp. We do get the odd tiny bit of mould around the window reveals as well.
As a decorator, I have had customers with walls and ceilings which they wanted to be repainted because of mould. I try to explain to them that they need to increase air flow. Waterbased eggshell will minimise the risk of mould. The downside is that any condensation will run down the wall, potentially on to any carpet.
Have you worked out yet where the water is coming from?
The wall does not create it.
That's a most unusual and least expected place for condensation mould to occur. Lack of air-flow is part of the equation and conditions for a mould-growing environment, and the area behind a radiator is going to get not just a lot of air flow but be a very dry area too which condensation mould just won't grow in.
I agree.
I'm wondering if the rad is ever turned on...?
There isn't a radiator. He has removed it. I think he's talking about a patch of wall where a radiator used to be, though it's not very clear. See posts 10 and 11.
