Silicone Render
22 Jan 2010
Sussex
Hello guys,
Can anyone recommend a silicone internal render? I've been asked to use it on one wall by BC.
Is Sika 1 what I'm after?
Maybe something similar as used when tanking basements?
J
There are different types of silicone render. K-rend is a type normally used for external finishes. The DIY sheds usually do silicone render or plaster pre-mixed in tubs. What's the application? And why does BC want silicone over a normal plaster finish?
It's as a base coat. Basically I had some problems with my cavity insulation, sorted it but BC want a silicone render as a base coat on one internal wall as belt and braces.
I was talking to a mate of mine last night who uses K-Rend and suggested that might do the job.
Do you think a skim coat would be okay on top?
