Hello,
I've a Single-impeller negative-head Stuart Turner Monsoon N2.0 pump on the Hot side and Mains-pumped on the Cold side in my house. The house has two showers, both of them equipped with a pressure equalising/ balancing valve.
Lately the pump seems to come on for a couple of seconds when the cold water tap is operated (mostly when its shut). It also comes on when the toilet cisterns are at the end of their filling after use.
The pump is around 10 years old and never caused an issue otherwise.
Any idea what might be causing it and how can it be fixed?
Thanks.
Thanks.
