Single oven with standard 13a plug
17 Apr 2006
My single oven appears to be on its last legs and I need to replace.
However the present single oven has a plug attached rather than a dedicated cooker switch or circuit that I have had in other houses.
Is an old oven so I am wondering whether I can buy a replacement single oven that will plug straight in?
Or do I need to fit a new circuit and then an oven that needs to be hard wired?
Thank you.
:oops:
Yes, most small 'built-in' ovens come with a plug fitted.
There may be a circuit behind the oven from previous use.
Do you have a circuit on the consumer unit which is not used.
It may even still be labelled 'cooker'
Plenty of ovens on the market with 13A plugs.
Could have been a dedicated cooker circuit in a previous life and been modified.
What size is the circuits cable?
How old is the house?
