Single skin wall, what foundation?
3 Sep 2008
Tyne and Wear
I am designing a garage extension with bedroom above. the neighbours are a bit funny so i would like to keep everything on my side of the party boundary. I propose a single skin brick wall at ground floor level to maximise space in garage. I then want to specify a lintel to support floor and inner leaf above. My question is about the foundation, is a trench fill acceptable to avoid the eccentric loading that would be placed on a strip foundation?
If you are spanning with a beam at first floor level, then the ground floor single skin wall is not doing much and so can be on a small foundation
But you are unlikely to get a lintel to span the length of a garage, so will either need two and a central pier (on a pad foundation), or a steel beam.
A beam will create a problem of how to cover it externally, [cavity] lintels may create a problem with uneven loading as presumably the ground floor wall will be under the external edge of the lintel
And trench fill and strip foundations are the same!
