Yes I am sure he will, but I need to make decision now relating to the layout of a room and W/C partition and where the boiler is more than likely to go. Dont want a plumber 2 months down the line telling me it's not possible to put the boiler there when its too late.
Looking at page 50, assuming a 30kw combi boiler, looks like I require 600mm clearance from a window (so I should be fine).
I also just realised it will be only 300 or 400mm away from an external back door, but I'm not clear from the table how far that should be???
600mm is for a natural draught boiler. Think you'll find your selected new boiler, which will also be condensing, will have a "fanned" flue which means 300 is OK
For another property, I understood that as my boundary line is about 500mm away from my wall flue, we can overcome this issue by having the flue come out of the wall and point up like a vertical flue and that will be complaint?
