I am in the process of putting central heating into my house and getting to the stage of choosing a boiler and running the gas pipes through the house, which will supply a 30kw combi boiler and a gas cooker.
What diameter pipe should I use for the gas supply, the distance from the meter to boiler is about 17 meters.
I am also wondering if there are any restrictions on how close the gas supply can be to the central heating loop. I plan to run it inside trunking (150mm x 65mm) which I put into the concrete floor of the house and already has the flow and return running in it. Even though I plan to insulate the flow and return pipes I am concerned the heat from these pipes may affect the gas supply? Maybe I'm too paranoid!
Would really appreciate any advice
