you can take it one more step and have more advanced controls.
for example having a room stat that tells the boiler what room temp is so it can range rate it self down, so the room stat tells the boiler
"we need the room temp to be 21c and it is only 10c so fire at full rate" then "ok it is 15c in the room range back" then
"ok it is 18c in the room range back even more" then
"ok it is 20c in the room, switch off and let the heat that is left in the rads to take it up the last 1c"
and it can also makes sure that that boiler is alway condensing to give you the most value out of every £1 of gas you use
ok...a bit over simplified but you get the point. then you could also add a out side weather sensor and then the boiler will know the outside temp, the inside temp and what the final temp you want in your house which makes the system even better
