Sizing Portable transformer for operating US 110V tools
Doesn't really matter as it will mostly be wattless current, just the iron losses of the transformer.
Have you invented another phrase?
Give us a clue what "wattless current" is :roll:
Just put an ammeter on the primary to my 110V transformer and it's drawing a steady 1.8A with no secondary load on it.
Not sure why there would be much difference between a yellow box and a wall mount transformer of the same rating... :?
I bet they're fun to fix to a wall single-handed.
Thats where the stud and nut type rawlbolt things come in handy.
So you're going to be travelling from the USA to here, lugging around 50kg of power tools with you?
If so they alone will blow your baggage allowance. Have you considered hiring tools over here?
I am traveling to Sri Lanka to do some home renovation to family's ancestral home. Don't want to buy tools there cause it is a huge hassle and selection is limited. I did buy some power tools there but it is much more convenient and cheaper to take my American tools with me.
Any of you familiar with this type of portable transformer? They are made in China.
Above is 3kva , intermittent I assume.
There is a 5kva one also.
I suspect that is not a transformer, but an electronic voltage converter. Avoid.
The yellow brick type 3.3 KVA is adequate for your needs.
Here in the US , those Black metal enclosure units are advertised as step down or step up transformers . Large chain stores like SEARS sell them.
Below US distributor of high end German power tools sells them for use with German 220v handheld woodworking tools. But it is referred to as a " Voltage Regulator"
http://www.timbertools.com/Products/Router-Scheer-HM25E.html
http://www.timbertools.com/Products/Accessories-voltage-regulator.html
Since I am using American 15 amp power tools , I would need 15 amp output sockets for the transformer? The yellow tool transformers in UK come with 16amp output sockets right?
Carroll & Meynell make a portable transformer for American tools with 15amp output sockets. I am planning to buy either the 2kva or 3kva (continuous rating ) ones shown below.
http://carroll-meynell.com/products/us-supply-autotransformers.html
Does it matter if I run American 15amp tools off UK yellow tool transformers with 16amp sockets?
