Skirting board/architrave Finish
8 May 2012
Durham
I a couple of rooms in my house the skirting boards run directly into the back mould at 90 degrees. To finish this do I scribe out the skirt on the back mould or do I just butt it up to it?
Cheers
Jacka
Normally just butted up , but there is always the option of plint blocks that can overcome a few problems and look quite classy too.
Never thought about those, but don't think they would go well in our house as it's a post war semi
Another one. I've decided I'm going to use a 3/4 quarter round on one of the walls where there's no room for a back mould. How do I finish the skirt into that round?
If I'm assuming correctly then your skirting will be approaching the quadrant at 90* to the door (i.e. I'm thinking the door is close to a room corner). It may be as easy to run the quadrant to the floor and cut out the end of the skirting to lap over the quadrant.
Exactly right! Probably be better to run it to the bottom and cut the back edge of the skirting off like you suggested. Here's a picture http://img525.imageshack.us/i/imagejqy.jpg/
I'm also looking to use 119mm mdf torus
Would you suggest anything else like just running the back mould straight into the wall?
You don't look to have enough room to overlap the quad without obstructing the door.?
In that case what would you do
Just run a right angle straight into the wall and leave tht whole edge?
I'll aso take a measurement of house much room I have to play with!
I did have a similiar situation in my house with the door frame being very close the wall. Here's a picture of how I got around it. The arctirave is replaced with a small quadrant. At the bottom is a small strip of timber that mirrors the plint block on the other side of the frame. The skirting is then run into this and the face of the skirting is scallopped out to ensure it doesn't foul the door. Skirting in my case is 7" with a simple chamfer mould but the process is the same. I should really have done some house work before taking the picture :oops:
