I laid laminate flooring in my kitchen and when I have gone to lay skirting over the top it appears the floor is on a slight slope. I have fixed the Skirting from the arcitrave on the door and going along to the opposite wall... When I have gone to lay the second piece of skirting if I want it flat on the floor where the skirting meets then it slightly raises at the other end (I am guessing where the floor) dips.
Is there anything I can do? I don't/can't remove the skirting as it is fixed under the current skirting I have put in, it is also under the kitchen unit legs, back panel and side panel!
Would I be able to fill the gap at the bottom of the skirting, sand and paint over? Or can I bend it slightly and nail it to the wall? (Will this just ping off over a period of time)...
I look forward in anticipation to your response.
