- Joined
- 4 Mar 2017
- Messages
- 51
- Reaction score
- 1
- Country
I am wanting to replace the laminate flooring in a room, however, it looks like the flooring was laid before the skirtings and the radiator pipes are right against the skirting. There is a radiator on the other side of the room with a similar problem so can't really just slide the flooring under one side and remove the opposite skirting. Same problem at both sides.
Any thoughts on how I might go about removing these skirtings and refitting them. Or is it too much hassle and I should just go with beading - not my preference at all. I don't mind fitting new skirting if this helps. I just want to be sure not to damage the pipes.
PJ
PJ
