    Dismiss Notice
skoda octavia 2006 air bag light
Discussion in 'Car Repairs / Maintenance' started by coopegas83, 24 Oct 2010.
  1. coopegas83
    coopegas83
    30 Aug 2009
    21
    Thanks Received:
    Birmingham
    Country:
    after recently cleaning my car have noticed the air bag light is on the dash board cant seem to remove it now any ideas has any one had the same problem
  2. Sponsored Links
  3. gregers
    gregers
    28 Mar 2008
    6,301
    Thanks Received:
    500
    Sussex
    Country:
    in what way have you cleaned the car?
    because that could be a clue,have you disturbed something?
    or it might be the clock spring within the steering wheel that needs to be replaced?thats if your version has 1?
    maybe the fault code/s need to be read so you know exactly what is wrong.
    something like vag-com but you will need to obtain the obd-11 cable.
  4. Burnerman
    Burnerman
    7 Feb 2008
    23,148
    Thanks Received:
    4,500
    Northumberland
    Country:
    Check under the front seats mate.....if your vacuum cleaner has split apart the connections for the seat belt tensioners, the air bag light will be on, as its on the same circuit.
    John :)
  5. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    Does the car have airbags in the seats? Take a look under the drivers and passengers seats to see if there is any wiring there which could have come loose.
    The only way to be really sure which airbag circuit is in fault is to have the car plugged into a diagnostic machine capable of displaying the airbag control diagnostic data.
  6. Mursal
    Mursal
    23 Sep 2010
    2,203
    Thanks Received:
    484
    Country:
    Ireland
    I agree, hopefully you wont have to get the fault codes reset.
  7. albysenior
    albysenior
    25 Oct 2010
    11
    Thanks Received:
    Yorkshire
    Country:
    i know these cars very well,and just by moving the seat back can cause the connection to ya side air bag in the seat to very briefly go open circuit
    al you need to do is find somebody who can just erase the codes and the light will go out....it does happen alot when people clean their cars and worse still with cars with multiple drivers
    hope this hepls
  8. Sponsored Links
Loading...
Share This Page
