Hi all,
Recently been having some issues with the old sky+HD box (Amstrad) and don't seem to be getting very far with Sky customer services so thought I'd ask here.
The problem being that recordings regularly fail or only part record due to 'Technical Fault 7'. Initially there was only some skipping in playback but now most recordings don't playback at all and I can rarely pause/rewind live tv. Even the search and scan banner now frequently says 'searching for listings' and takes an age to show the picture when changing channels.
Contacted Sky for help and they got me to do a planner rebuild which didn't help so then updated system software which also didn't work. Finally had to resort to full system reset.
That seemed to work as the first few recordings afterwards were fine but then the problems started all over again. I've had to do full system resets countless times now just so that I can record/pause/rewind for a few hours at a time (a whole day if lucky
As said, Sky don't seem to be able to offer much more advice, and would probably expect me to buy a new box (no chance - will cancel it all first!) so can any of you please offer any suggestions or information as to what I can do and also as what Technical Fault 7 actually means?
Cheers
MrH
Cheers
MrH
