Your high definition TV will come into its own for DVDs provided that you use a good quality connection from the player, ie NOT composite video!
The standard for HD TV is 720 lines so if you paid extra for a 1180 line TV then you wasted your money UNLESS you want to play blue ray discs, which are currently the only source of genuine 1180 line video. They are way overpriced at the moment but I think they're here to stay and so they'll get cheaper. Standard DVDs certainly did. I had planned to transfer my old VHS tapes onto DVD but when I see one I want for £3 or less I just buy it.
gday2uk said:With standard DVDs you can get better quality with a progressive scan capable DVD player but only when connected to the TV through component video connections labeled Y, Pb, Pr.
As for the standard for HD, this is and always has been 1080p. There are all manner of articles on the web about 720p, 1080p, 1080i etc.
The issue is that there are very few full-time HD channels.
Sky One HD for example just upscales all the normal Sky One output and then inserts HD versions of the programmes where available.
Actual HD programmes are flagged accordingly in the Sky Planner.
Steve
If I switch from Virgin to Antenna, the Virgin picture is lots better than the Antenna.
