Sliding shower door leak
28 Mar 2022
Mum has moved into a lovely retirement flat but there is a problem with the shower cubicle.
Water streams through between the sliding door at the bottom (noticed this as I was spraying down the cubicle from the inside - didn’t seem to happen while I was showering). There doesn’t seem to be water come from the fixed panel - just the sliding door.
What do I need to do to stop this please (apart from not spraying the door from the inside )?
photos and a wee video at the link below
https://share.icloud.com/photos/07cG3i4WdFR3D_7OSDmyOeRUw
Thanks in advance
Looks like there a deflector or inner seal missing. Usually these doors have a deflector panel at the bottom of the door inside that directs the water away from the lower section or a seal that stop the water running down the gap.
Thanks for replying - can you please point me in the direction of what I need?
Unfortunately it's not as simple as that, wish it was.
Without knowing the manufacturer it would be really hard to retrofit something for that model, especially a type who's door runs on the outside of the enclosure. Most these days run inside.
Bummer - so am I looking for a whole new shower cubicle front screeen?
Not necessarily, are there any makers names on it anywhere? have a good look about. If you can get a name then there's a chance that the needed bits can be sourced. There are sometime tabs or makers names stamped or labeled in places like handles, runners, corners of the frame etc.
If you can't find any markings then the only option may be a new enclosure. It may also be worth getting a professional that experienced in shower fitting that may be able to look at it and spot what's wrong. What they may be able to do about it though, if there isn't any makers markings, may be little.
I’ll have a proper look at it on Sunday and see if I can find any markings. Thanks for your guidance
I found a leaflet in a cupboard for the side panel. Looking at Lakes website, I think this is the sliding door. Will try contacting them - unless you have any more advice? https://lakesshoweringspaces.com/wp-content/uploads/2017/04/V1-Sliding-Door.pdf
Erm yup ... get an installer in and get them to take the screen out, turn it around and refit it.
If that is the MI for that screen, which it look like it is, the screen's been put in back to front. The sliding door should be hung and run on the inside of the frame (Pic D), not on the outside. No wonder it's leaking.
Lakes have just phoned me back to confirm exactly what you’ve said! The poor man before Mum must have been mopping his floor for years!
Im off to find someone to turn it around.
Thanks so much for your help
