Slimline Classic SE12 FF Boiler not igniting.
18 Oct 2009
Glasgow
Tried the basic steps to re-ignite the pilot but not happening. Noticed something on circuit board is flashing on and off. Also says you can reset the overheat button on the diagram, but there is no button on actual appliance. Any ideas on solving this most welcome, even if it's only, "you're boiler's goosed mate and needs a certified engineer" :D
Sure there is not an overheat button on right hand side just where electric cable comes into boiler.
Is fan working
Is fan working
definitely no button. don't know about the fan not working.
shut it all down last night, and tried to start it again this morning. kicked in ok so fook knows what was wrong with it.
Heated water up, then tried CH, and it initially worked ok, then stopped working again. Shut it all down again, and exact same scenario today.
Any ideas?
My boiler is doing the same. I believe this to be a fan fault.
Can you confirm what your issue was and how you resolved it?
I will post my update once fully fixed!
Kind regards
Kevin
Hopefully a gas reg engineer will know what is wrong and sort it out for you!
Tony
