- Joined
- 27 Jan 2008
- Messages
- 28,739
- Reaction score
- 3,508
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In case you read this before what I have said on other post with the C Plan you seem to be running there would not normally be a need for two line feeds unless there is a flue fan and I worry that permanent line and run line have been swapped.
This could produce CO and I would advise it is time to bite the bullet and get a proper heating and ventilating guy to fix it before you kill yourself with CO. CO2 is bad but no where near as bad a CO which will be produced if a flue fan stops.
Forget about fuse and get it done safely.
