Slow filling fill valve on toilet cistern...
31 Aug 2022
I've seen a few threads on this subject, but in my particular case, the fill valve is a side-entry.
The toilet was fitted 10 years ago and is the main family bathroom, let's just say it gets plenty of use. Over the last few weeks it's taking a good 6-7 mins to refill after flushing.
I had a similar issue with a downstairs toilet, and the fix for that was to replace the diaphragm washer. However, this valve (pics attached) is a different type.
I don't know if the side-entry fill valve has a diaphragm fitted, or even if this valve has any serviceable parts, in which case I might have to replace the entire fill valve (the plumber who fitted it kindly left the installation instructions in the cistern cabinet, valve is NJ313, I googled it and it's a flushdaddy fill valve).
Would I need to replace the whole fill valve? Thanks
A few £ for a replacement washer or £10 upwards for a new valve. Maybe buy a couple of washers?
Thanks, I think I'll replace the whole fill valve - seen a few videos and it looks like an easy enough job. Cheers
UPDATE: Fitted and all working again.
When I fitted the new fill valve I gave the toilet a flush, but it didn't refill! I thought oh no what's gone wrong...then realised that the inverted cup was stuck against the cistern sidewall because I'd not installed it perfectly vertical. Readjusted and all good after that. Cheers for the help.
