slow filling toilet cistern
30 Mar 2007
Staffordshire
Hi there
I have a push button flush toilet which is taking ages to fill. I've read the numerous posts and found that the siamp diaphragm is the likely suspect although ive also read that id be best off just replacing the flush unit as a whole.
I have found this : 51173: Fluidmaster Push Button Cable Dual-Flush Valve in screwfix which at £11.99 seems not much more than the diaphragmonce II've paid p&p.
what are your thoughts? Is the screwfix system any good? The original was a toilet to go b&Q bargain so i didnt expext it to really last as long as it did.
Dougie
Hi Dougie boy, if it's slow filling it'll be the float valve that's faulty. Most now are equilibrium type valves & can be a bit temperamental. Just replace that with a Fluidmaster inlet valve, just ensure it'll adjust enough for your bog.
HTH
