Slow running hot tap
18 Feb 2006
Birmingham
Hi all
Got a gravity fed system and having trouble with the kitchen tap, where the flow is very slow.
Cylinder is in the bathroom, bath tap is perfect, basin is ok but not as great. Kitchen downstairs is abysmal. Is there anything that I should be looking out for as really need to sort this
Many thanks
I would firstly look at the pipework supplying the kitchen tap. If it is a mixer tap ,with braided flexible hoses ,their internal bore is tiny and restricts the flow quite a bit. Even though the cold might be great the hot is not under mains pressure and there will be a noticeable difference .check this out first
Hi
Thanks for the reply. It’s been fine for a few years, never been the best but all of the sudden it’s like a dribble.
The tap is a mixer tap
Then the tap valve would be my next port of call. Do you have two separate tap heads or is it the single lever type ?screw down tap heads or quarter turn ?
Hi
It’s a single lever mixer tap. It’s a moretti tsp in the link, just realised it’s not suitable for low pressure systems.
http://www.ie.screwfix.com/moretti-pull-out-sink-mounted-mono-mixer-kitchen-tap-chrome.html
There’s also a full bore valve in the hot side which is hard to turn, wondering if this isn’t opening fully
Its not a gate valve is it ? Big round red handle ? Notorious for not opening / closing fully ,after laying dormant for years you turn them off / on and you find you have a problem. Also check where the hose meets the tap ,and the end where water comes out ,for any signs of blockage ,limescale usually.
See lower down in the link. It States " not suitable for gravity fed " Hmmmm.....but its been working OK for a while , so summats changed ??
  • Suitable for High & Low Pressure Systems
I'm with Terry, faulty gate valve.
Andy
Not a gate valve, just a full bore isolation valve, which was fitted by me 3yrs ago when I did the kitchen.
I'm going to disconnect feed to the tap and check flow into a bucket, if it's not good then drain the tank and change valve for a lever valve anfpd see if that improves
I've also purchased a new Franke Mythos tap to replace current one if needed
If it's suddenly bad on one tap it's got to be done debris, especially if it's the lowest tap.
Could be lime scale, or some crud from the header tank, I had this and removed the tap and flushed those tiny Flexi hoses through backwards. I could see through them afterwards and the flow was miles better.
If it keeps happening, eg for people who have certain combis in a very hard water area, you can fit a Y strainer on the boiler outlet. But unlikely to be a major issue for you if your header tank is pretty clean and covered.
Good luck!
Good luck!
Thanks for the info, could well be considering how small the bores are on flexi tap tails. I did remove ceramic cartridge last week to clean, but all looked ok
Good idea but first accurately measure the hot flow at the tap,time how long it takes to fill a pint glass.
Then measure at the feed pipe (as you mentioned) see how long it takes to fill the same glass.
If braided flexi pipes are used,you could undo the hot from the tap inlet and do the timed glass test,the flexi hose could be creating excessive restriction.
the time taken will indicate where good water supply is available and not.
Other consideration is to check the loft water tank is at the correct fill level.
Any braided flexi pipes should be as straight as possible.
A lot of those monoblock mixers are suitable for mains water only at balanced pressures,so it may have been just about supplying sufficient hot water but mixing hot&cold when rinsing using the pull out spout will be hit or miss.
Have changed a few fancy newly installed monoblock kitchen taps for the Bristan mono value (not ceramic disc) taps.Works a treat.
could well be considering how small the bores are on flexi tap tails...
The spec I readon the link you posted states it has solid tails to the tap.
In any case you can disconnect the hot feed and backflush cold mains water through the hot tail to dislodge any debris into a bucket. Then flush the hot pipework, as you've already suggested.
As far as scale is concerned, isn't the West Midlands a relatively soft water area?
Well spotted, couldn’t remember if flexi or rigid. I’m supposed to go over later, will see how it goes
