I want to connect some flex to some fixed cabling to power some lighting. Normally, I would use an FCU. However, the connection needs to go on top of cabinets and there is only about 50mm between the top of the cabinet and the ceiling which means there is insufficient room for a normal accessory. I was thinking about using something like:
http://www.qvsdirect.com/Surface-Junction-Box-c-w-3-Pole-Terminal-Block-pr-24142.html
But maybe there is a better product, or better solution..?
cheers,
Radweld
cheers,
Radweld
