Small cable/wire size
I'm after some very small wire/leads to connect up to a PP3 9v battery, same size as shown here.
http://www.maplin.co.uk/Module.aspx?ModuleNo=44392
I can't order any without knowing the size of wire - any advice appreciated.
If you have an old pc lying around use IDE/Ribbon Cable, the type of used to connect your hard drive or cd drive to the motherboard. If not Bell wire should do or even speaker cable.
