Hi,A few numbers might help.
If pipework is 15mm then 3M of pipework will contain 0.37L of water and take 3.7 secs to empty before the hot water reaches the tap assuming a flowrate of 5LPM. It would take 50M of 15mm pipework to take 1 minute to empty before the hot water reaches the tap.
If the pipework is 22mm then the corresponding times are 8.5 secs for 3M and will require 21M of piping to empty in 1 minute. This assumes that the combi preheat is in use & hW available "instantly".
Thanks for those figures - can't see how they help however.
Combi pre-heat is ON.
Theres probably about 5 seconds from hot tap on to hot water leaving the boiler- yes that's way too long, very wasteful of energy and water.
As soon as you turn the hot tap on, you can hear the boiler firing up straight away.
Wait a min, then the water starts to run hot.
Lord knows how much wasted energy and wasted water is involved - and this is a house with a water meter!
Maybe a little crossover is the problem if a thermostatic mixer tap?
Don't understand this question.
XRD
