My project summed up in one sentence:
Convert studio flat into one bedroom flat by moving kitchen units into main space and make kitchen space into bedroom.
This forum is a great resource and I am posting this thread in the hope of getting as much feedback as possible.
See below drawings (approx)
Current
Intended result
Job #1
Moving kitchen into main space:
Fortunately, soil and water pipes enter/exit the flat in corner. I intend to set up new kitchen units against north wall (left wall in drawing) I will extend plumbing along wall a few meters and over this stretch there should be a sufficient drop for wastewater to flow freely back to soil pipe.
Main space will need cables and plugs to be used for fridge, electric oven and hob, washing machine, plus a couple of outlets for toaster etc.
Electric wiring and pipes will go trough wall between kitchen and main space, which becomes part of job #2 below.
Job #2
"Straighten" wall between kitchen and main space.
I am quite annoyed that there are small closets built into the walls. These are constructed of the same one-brick structure as the wall itself. I would like to knock trough wall where closet is built between kitchen and main space (see drawings) and erect stud wall in line with rest of wall.
Stud wall facing main space should ideally be clad in material where I can hang shelves. What is the cheapest insulation? No need for anything fancy, just want to make sure wall doesn't have hollow sound and feel.
Piping and electricity mentioned above will run trough stud wall.
The other bit of wall to be knocked down is a 40 cm wall sticking out from east wall (top in picture) and partly covering built in closet in south east corner of kitchen. Closet will stay as it is, only I intend to enlarge opening.
Job #3
Freshen up main space.
Paint ceiling. Rip off wallpaper. Remove carpet.
I would like to go over bare wall with either Polyfilla or Easifilla then sand down and paint. I imagine many of you will be aghast at this, but I need to go cheap.
Which is better; Polyfilla or Easifilla? Do I cover filler with adhesive like PVA or similar before I paint?
Rip out old carpet and cover naked concrete floor with garage floor paint. I will consider other flooring in a year's time when I have a bit more money.
Project management
Hackney council tells me over the phone that this project doesn't require a planning application, but must have approval of Building Control Dept.
The latter are mostly concerned about whether internal walls are load bearing and that plumbing and electrics must be done by pro's.
I am 99% sure that the walls around the kitchen are not loadbearing given the overall size of the flat. I just need to find the cheapest way I can have this confirmed. I am wondering if I just tell the council it is when I hand in the paperwork and wait for them to inspect and confirm? Alternatively, will plumber's assessment be adequate? If not, how much would it cost to have an engineer visit?
I will need a plumber. Is this one day's work? How much for materials?
I will need an electrician. How much approx?
I intend to knock down brick and make stud wall myself.
I intend to fix wall in main space and paint myself.
This ex council flat in North East London is valued just over the 100 K mark so I feel that the budget of the improvement must stand in proportion to this - otherwise I might not get my investment back when I decide to sell.
For everything I have described I imagine you must have plenty of comments. All suggestions, criticism and help will be received with thanks!
Current
Intended result
Job #1
Job #2
Job #3
Project management
