Small PVCU Window?
22 Aug 2010
London
Hi Guys,
Trying to find a very small PVCU window to fit an openign of 450 wide by 600 high (including cill). Surprisingly difficult to find anyone who can help supply this? Anyone have any ideas where I could go?
Cheers Mac
There is a requirement to provide emergency egress windows to habitable rooms on the ground and first floor levels of up to two storey dwellings unless a protected route is provided from those rooms to the final exit.
All habitable rooms on the ground floor should either open directly into an entrance hall or other suitable exit or be provided with an escape window. This has had a great impact on which window frames can be used for escape purposes and where they can be used.
Windows which meet fire regulations are those with an unobstructed clear opening area which is at least 0.33m2, with a minimum clear opening dimension of 450mm in either height or width. The lowest part of the opening must be between 800mm and 1100mm from the floor.
With the above in mind you can have UVPC window made to any size you require
Regards oldun
Regards oldun
This only applies if the existing windows are escape windows, the rules simply state that replacement windows should be no worse.
Hi Guys,
Cheers Mac
Look in the yellow pages for local fabricators. I have seen PVCu windows much smaller than this.
Or the online window manufacturers might do it (but these might be the ones that limit sizes of "standard" orders).
Avoid at all costs the National places - Everest or whatever.
Could be wrong Fred, but to the best of our knowledge this is a window for new extension. so have covered our back side as best as we can.
Down to OP now.
Regards pldun
