I have a shower mixer that is connected to the hot and cold supply which are both 1/2" male fittings by way of flexi-hoses. Hopefully this explains better that I can:
Problem being is that when it is left open it allows the hot and cold to mix. I therefore want to add a check valve to the hot supply. Is there a very compact 1/2"Female-to-1/2"Male valve that I can put between the existing connectors? Obviously it needs to be as small as possible to allow the casing to be mounted back on the wall when connected.
