I'm using some Ronseal Daimond Hard Varnish on a box. I've used a sponge roller and a brush on different coats (and test pieces) an both leave significant texture. I've sanded which helps but the next coat is never perfect.
The best finish I've got so far is applying the varnish with a sponge and sanding with 360 grit. But this still leaves some light texture (looks like brush strokes) and doesn't get as smooth as I'd like.
Am I doing something wrong or do I need to use some wet'n'dry, and if so can I expect a perfectly smooth finish?
