Hi Guys,
Quick question which has been puzzling me for a while.
So im laying snap together engineered wood flooring in our hall, I have cut out the door jambs to fit the flooring under, I understand how to slide the flooring under the door jamb when im fitting the flooring length ways but what about when one plank goes between 2 door frames (specifically a door under the stairs).
I wouldn't be able to lay the floor at an angle as the door frames will be in the way, so do I have to cut out the tongue and groove and slide the plank under from the other side of the door (under the stairs?).
many thanks!!!
many thanks!!!
