Two of our neighbours had conservatorys built last year, both with an electrical system.
One
Wiring was an extension of the existing downstairs RFC from a socket in the kitchen, 1980s wiring so no RCD, no work on CU to fit one
Cable run in cavities that were filled with insulation
Cable in places not in safe zones
Cable run in floor screed in oval PVC conduit and concreted in, this below the underfloor heating system
On vertical runs on one or two clips used and no capping
Two
A stand alone system fed from an RCD that had been installed to control outside supplies to garage with a 2 way CU (also controls an existing small extension)
Neatly clipped in safe zones and capped
No cable in floor screed
Which is physically the safest system?
Guess which one was issued an EIC?
Though some seem to think that an EIC is the be all and end all, it is just a piece of paper that may, or not, get filled in.
But there is no doubt that the existence of one does not make the wiring safer or show that Part P or BS7671 has been complied with.
As it is both houses will probably never change hands for a good number of years at which point an EIC would probably be irrelevant by then anyway
One
Two
