Soap draw on washing machine leaking
18 Aug 2008
London
How much would you expect to pay to get this repaired?
My plumber confirmed it's leaking but he doesn't do appliances.
What would typically have lead to this?
I have the model of the machine off hand, it's a mid-range currys I know that much
7 Feb 2008
Northumberland
What's happening, Hawk? Is water gushing out of the front of the drawer due to a powder blockage in the tube leading to the drum maybe, or has the drawer itself failed?
John :)
18 Aug 2008
London
I was told by my plumber ''it's the soap dispenser'' so I told the tenant to follow the manual instructions on how to clean out detergent gunk before I send someone out. We'll see what comes back.
7 Feb 2008
Northumberland
I see.....typical faults are the water jets from above blocking up with sprayed back powder (particularly the fabric softener which is low volume and pressure), the siphon on the fabric softener tray blocking up with gunge and overflowing out the front and the tube from behind the drawer clogging - as I mentioned before.
Soap capsules chucked straight into the drum helps things a bit.
John :)
18 Aug 2008
London
Thanks for the tips. If the water jets are clogged I wouldn't expect them to fix it on their own?
Polish couple; and she had trouble switching the oven on when they first moved in.
I'll be inadvertently making it a repair and not a maintenance issue if I send someone out. Was quoted £50 + vat before parts no matter what the problem is. The worst sort of tradesmen are appliance repairers, I'd happily avoid avoid avoid but this may not go away by the sound of it.
7 Feb 2008
Northumberland
I don't think you have any option mate.....regarding the water jets I have got in there with a toothbrush in the past, and even a cocktail stick on occasion to help things along without taking the washer top off.
For sure, I'd guess the tenants couldn't give a toss what the fault is.
John :)
18 Aug 2008
London
Tenant now says the leak goes away for three washes but on the fourth she has to clean it out again. Any ideas ?
I've said use the tabs in the drum and see if that cleans it out, as the draw fills up regardless of whether there's detergent in it or not?
If that fails I'll have to call someone in on it.
14 Mar 2006
Kent
The draw is removable and easy to clean , drop in a bucket of boiling water, is the draw is not clogged and actually damaged then replacement draws are available and just slot in.
18 Aug 2008
London
Do you think the defect would likely occur from overuse or misuse? I like the idea of sending them out another part but what's the reason it can fail other than cracked plastic? I know what they look like and generally there are no washers or seals that can fail?
7 Feb 2008
Northumberland
The only thing that gives issues is the fabric conditioner drawer syphon.....if it's blocked with gunge the syphon just doesn't work and water overflows.
Is the place too far away for you to look in?
John :)
