- Joined
- 29 Mar 2005
- Messages
- 178
- Reaction score
- 0
- Country
Last night I was minding my own business when suddenly the RCD trips out.
I work out that the circuit with the fault is one of the ring mains (the only ring I haven't actually worked on aside from actually wiring the ends into my new CU). I go round pulling out all plugs from the sockets on that circuits and the RCD *still* won't stay up (I switched all other MCBs off so I'm just testing that one circuit).
I eventually discover that, despite nothing being plugged in to it, I have to turn the switches on a particular socket into the off position before the RCD will stay on. Leaving nothing plugged in, if I flick the switches into the on position the RCD trips out immediately.
I replace the double socket with a new MK one I happened to have and it's all fine now.
Does this sort of thing happen often? The old socket is about 20 years old (I assume - it's in the extension which was built in 1987 and I assume it's original). There's no visible mechanical damage nor is there any indication of it getting wet (it's on an internal wall anyway). It's not a make I've heard of before but then again I'm not an electrician so I don't see many installations to that level of detail.
My wife wasn't best pleased because it happened in the middle of her recording a film on Sky+ ...
