I've found a couple with a hole cut in the PB leaving enough where the lugs should be to fix the accessory with no4 screws instead of using a backbox or the brickwork drilled and rawlplugged and no backbox.Maybe there's a market for sockets etc with their own removable cover on the back, which fixes to the socket, and the socket is then screwed to the plasterboard or cabinet?
Actually I've used that trick myself where the lug is missing, drill through the backbox into the brick and rawlplug rather than disturb the decorated finish to replace the backbox.
