I'm just having a conservatory built - well they start in a couple of weeks.
I'm wanting to put some sockets along the dwarf wall. I have a double socket on the ring main on the other side of the wall to where I want to start, so it should be a simple extension of an existing circuit, keeping all new sockets on the ring main. The ring main should have plenty of capacity as we have two ring mains and that's the secondary one which just covers the extension (1 bedroom, garage and utility room)
My one question is that there is going to be a double door in right in the middle of the wall I want to put the sockets in, what is the correct way to span the door. I'm aware that all wiring must run vertically or horizontally from sockets to comply with regs.
Do I run horizontally at socket height along the wall then put a double socket near the door and run vertically down at that point then run along under the floor? I was slightly concerned incase the double door is screwed in place into the floor - don't want them to go through cables!
Thanks for any advice
