I am having a new single story extension built. To keep costs down i am doing as much myself as i can. The building inspector is happy for me to do the wiring myself as long as he can see the cable runs before i cover them up and that i have an electrician test the system. He will also be installing a new consumer unit. I have an electrician to do this. The building inspector is also happy to have the sockets heights the same as in the rest of the house
I am having 7 double sockets and an external double socket. I am going to have these sockets on a ring. I want to be able to switch the external socket on/off my inside the extension. The consumer unit is in the dining room (approx 12ft from the extension). The wires will run up above the consumer unit to the ceiling, through the joists and out into the extension. the extension will have a vaulted ceiling, so these cables will come into extension and then up into the ceiling joists where they will run round until they drop down to each socket and then back up to the joist and then along to the next socket.
Where a cable runs through a joist does it have to go throught the middle or is there a different requirement. What do i use to switch the outside socket on/off. Cables will be running up from the socket to the ceiling inside conduit
Is there any other information i should know?
