Soffits - for garden room
30 Mar 2015
My garden room has osb lined walls and this will be wrapped with membrane and vertical battens, ready for my final cladding layer.
I’m wondering, is there any issue with fitting the soffit after the battens? It will mean that I don’t lose some of it under the battens (and cladding), where it won’t be seen.
Is there any issue with this approach?
No issues at all. I would frame up the soffit first, i.e. fix the ply boarding etc ready to receive the décor finish.
Thanks for the prompt response.
My garden shed will have the 5x 2 joists overhanging at front, around 50cm with a ring beam on the front. I was planning to nail the soffit to these joists. They are centred at 400 so should avoid any soffit sagging. I have a similar but much less smaller arrangement at the back, where the gutter will be. On the sides, I have a overhang, constructed as a ladder. Again, al of these will have the ring beam.
I am thinking that once I have battened the membrane down, I can work out the exact overhang (I guess I still don't know about the thickness of my cladding) and then get a soffit board slightly smaller than this, so no cutting is required across the length and when the fascia slides on, it has a lip which will cover the few mm shorter width of the soffit.
Also, I am thinking of having a 10cm overhang at side and back (beyond the battens and including the ring beam). Does that seem reasonable and does it match up with standard soffit sizes? Not started looking at what's available yet.
