Hi just looking for some advice on the following please
I have a downstairs bathroom and the soil pipe itself has no vented stack pipe if that's the correct thing to call it.
The current arrangement is a clay soil pipe (I'm at the bottom of the drain in the street so it has about 4 or 5 sections or clay going vetically down right behind the toilet then curves out into the back garden and into the mail drain gulley type thing.
The soil pipe had been leaking and on checking it, the rubber adapter that was stuck in the top of the clay collar had split the clay pipe, so I have dug down to the next collar which is cemented in and using my angle grinder I was going to cut away the damaged section hopefully leaving the next clay section and collar undamaged. I was then going to get an adapter to do clay to plastic and put a new foot or so of plastic in and pack with pea shingle to hold staight then connect toilet back to the top.
I would like to put an on-suite upstairs if I can and need an addtional soil pipe connection. Is it allowed to put a T section adapter in as the top section replaceing the broken clay section and the feed the onsuite at a later data into that. The problem that I can see is that it's below the floor level but the drain is actually about 5 feet down under that.
Can you give me some thoughts please? am I allowed to connect both toilets to the same soil pipe?
the other way I consider was scrap the soil pipe inside and dig down outside and remove the old clay pipe then add plastic right into the main sewer but this a lot more work, or leave the current arrangement as it just adding a small bit of plastic to connect the toiler back up and dig down say a foot outside break into the inspection chamber (on my land) and put a tumbler in?
thanks
thanks
