Hi all,
I did have a quick look to see if this has been covered before, but couldn't see anything. Here's my problem..
My house is about 10 years old, and has an internal soil stack. This connects inside the loft to a roof vent, via some PVC flexible hose (a la tumble dryer). The PVC has degraded and started to tear, which is letting water leak inside the loft. I've tried to repair the PVC house with duct tape and glue, but the water has leaked through the tape. So i've replaced the section of PVC ducting that was damaged with a new section, and used the circular double-ended plastic connectors to attach it to the old ducting hose and to the the black rubber roof vent hose. I attached it with 100mm jubilee clips at either end and did them up tight.
This hasn't fixed the problem, there's still leaks from both ends of the section I replaced. So my questions are:
Should there be this much water in a pipe that's supposed to be venting gas? I'm not sure if it's condensation, or perhaps rain leaking back into the vent from the roof..
Is PVC flexible hose the right thing for this job, or should it be replaced with something rigid?
Anything other ideas?
Thanks,
Adam
Thanks,
Adam
