OK, possibly stupid question here...I've just moved into a house that has a solar thermal system for the hot water. I want to replace and relocate the cylinder, and so I need to know what size the corrugated stainless pipe is. Having not worked with it before, it's not simply a case of looking at it.
Is DN16 roughly 16mm outside diameter, or 16mm inside diameter? The obvious method of looking at what's printed on the nuts hasn't helped, as it doesn't say! The nuts are about the same size as 22mm compression nuts
Thanks in advance
Thanks in advance
